Page 6 of 72 FirstFirst ... 456781656 ... LastLast
Results 101 to 120 of 1440
  1. #101
    There is still one genuine Healey 100S AHS 3908 (ex Jensen) that has been restored in Christchurch
    Name:  Ex Jensen 100S.jpg
    Mike Sexton has built a replica 100S which is very accurate and a fantastic example of what can be achieved.
  2. #102
    This really is for the avid Healeyite, variations on an A-H 100, the three versions.
    Chris White's 100M, kit the car was a 100 that Chris modified to " M " Specs, and did a very good job at the time.
    Attachment 34043
    view from the other side - showing " Cold Air box and trunking to the grille, made a difference
    Attachment 34044
    A 100, unsure whose but could be IA 1004 which was owned by the late Gavin Gullery - information from Mark Donaldson, Founder and Historian for the AHCCNZ.
    Attachment 34045
    another view of the 100
    [ATTACH=CONFIG]34046[/ATT
    and another - small circular air cleaners rather then the cold air box
    Attachment 34047
    The photos were taken as I wanted some good reference shots for my car which was somewhat unoriginal
    The cars above were driven to and from the NZ event, and indeed most events
    For comparison a 100 S engine, cross flow with the carbies on the other side and no air cleaners or cold air box - this photo from Snowmass, Colorado in 1982. The car arrived in a large trailer and had travelled from the East Coast to Colorado.
    Sadly no 100 S remained in NZ. that I am aware of - unless tucked away somewhere or recently imported [ as in the last 20 years, since I left the NZ Healey club, having sold my Healey in 1995.
    Attachment 34048
    You say crossflow but all I can see on opposite side of head is spark plug's
  3. #103
    Maybe you need the thread title changed Roger - Austin Healeys! There's enough material around to keep it going. I'm sure Steve could manage that for you - though he is busy.
  4. #104
    A Healey thread sounds good to me.
    I found these two photos in the Moss archives taken by Paul Debois if that is of interest to you "Healeyites"
    Name:  Healey 100S engine.jpg
    A 100S motor.
    (Note the modified chassis brace below the hood/ bonnet support rod. )
    Name:  Healey 100M Engine.jpg
    A 100M engine.
  5. #105
    Cambridge NI NZ.
    I think Mr Dowding is mistaken.......there were no cross-flow heads on Austin Healeys.....not from the factory anyway.
  6. #106
    Southland
    I cannot see cross-flows, but some 5 port heads with ports on pushrod side and others with ports on non pushrod side, these appear to be an eight port version.
  7. #107
    Quote from my !00S information:
    The 100S engine featured a Harry Weslake-designed aluminium
    'single-port' cylinder head with reversed manifolding and it became
    unique to the 100S – (total production of only 50 or so customer cars,
    plus just the handful of Works cars). So in effect, this was a bespoke
    engine – and a good reason why the 100S has been so rarely
    replicated.
  8. #108
    I found some more Healey 100S information in our Moss archives from 1955. I hope they can be read ok.
    Name:  Healey 100S # 1.jpg
    Name:  Healey 100S # 2 .jpg
    ( Ken Hyndman )
  9. #109
    Austin - Healeys - the Austin Healey Car Club of New Zealand and others
    ERC, Yes I must, I tried to change the First Post but doesn't do the Heading, and I have 100's more Healey photos going back to the mid 1970's in NZ, and from two trips to the USA in 1982 and 1988, plus in England on the 1982 trip, some posted elsewhere [ a few ] but would be better here.
    Will PM Steve as it is a great idea, thanks Ray ..
    Steve if you are reading this can you do it !! thanks.
    Roger D..
    Name:  AHCCNZ Otaua Hill Climb 1985 - 88 #44 Healey 100 Chris White CCI07122015_0003 (780x538).jpg
  10. #110
    Correction to previous post ..
    Kevin, yep got that wrong, but they did move the manifolds inlet and exhaust to the other side so a very different head, somewhere in my Geoffrey Healey books [ 3 ] and Donald Healey books [ 2 ] there will be the reason. I know that LHD Hundreds got bloody hot for the driver as the exhaust was under your feet, 100S solved their problem but not for RHD 100S owners.
  11. #111
    AMCO72, yep as just posted got it wrong, I meant that the head was very different as shown by BMC BOY and others, means you guys are following this thread though, cheers.
    Any input is appreciated, Roger D..
  12. #112
    [QUOTE=Roger Dowding; they did move the manifolds inlet and exhaust to the other side so a very different head, somewhere in my Geoffrey Healey books [ 3 ] and Donald Healey books [ 2 ] there will be the reason. ]
    Roger, I thought what I entered on Post # 113 explained the reasons for the Weslake head design or did I miss something ?
    Yes, I am following your thread also !
    KH
  13. #113
    [QUOTE=khyndart in CA;51860]
    Quote Originally Posted by Roger Dowding; they did move the manifolds inlet and exhaust to the other side so a very different head, somewhere in my Geoffrey Healey books [ 3
    KH
    Great stuff, most informative, allway's loved them, what gearbox, diff etc, did they use on S model's.
  14. #114
    Kevin,
    Here are some specs on the 100S from 1955.
    Name:  Healey 100S specs.jpg
    The 4 speed gearbox was the same BMC design that was used in the BN2 model. It did have a special close-ratio gear cluster.
    Ratios were ; first, 3.08; second, 1.91; third, 1.33 and 4th was direct. No overdrives were fitted. Rear end was a spiral bevel type with a standard final drive of 2.92 to 1. Alternative ratios were available.
    (Ken Hyndman)
  15. #115
    A-H 100 S the engine and head ..
    KH
    All good Ken, didn't read the fine print, about the pushrods and better flow of the head with the manifolding changed over..
    Where do you keep all the stuff you post, must have a big Man Cave !!, cheers Roger
  16. #116
    Roger,
    It certainly helps to work at a place like Moss Motors in Goleta, CA. The company has been around since 1948 and there are many cupboards of books, magazines, blueprints, newspapers etc. It is like working in a automotive museum and getting paid for it !
    I feel very blessed.
    Ken.
  17. #117
    There is one local who has had a very nice 100S replica built up. Ellerslie 2004. (He already has a beautiful Healey 100.)
    Attachment 34053
    Goodwood Revival 2009, there was a good turnout.
    Attachment 34052
    Hi Ray, are you saying that the 100S in the first photo is a replica? Because that is a genuine 100S - it's lower grille makes it distinctive amongst 100Ss. You photographed the same car at Goodwood 5 years later.
    The car was first owned by a guy in the USA called Vincent Sardi (http://www.georgeellis.com/100). After a number of owners (http://www.racingsportscars.com/chas...HS%203507.html) it went off the radar and was discovered by Bill Lillibridge, who restored it and, during his ownership, shipped it to NZ at the encouragement of someone high up in the AHCC at the time (around 2004 by the look of it). It hung around NZ for about a year, while being offered for sale internationally for (IIRC) USD $250,000. To begin with the NZD was worth 50 US cents, making it a half million dollar car (http://www.nzherald.co.nz/motoring/n...jectid=3549133).
    By the time it sold, the NZD had strengthened and the buyer had negotiated the price down - my recollection is that it ended up selling for the equivalent of NZD $350,000. I (like several others) got to store and drive it. Nothing I've driven since comes close in terms of cost!
    New Zealand Classic Car magazine even did an article on it: http://magstore.nz/products/nz-class...-164-august-04
  18. #118
    Hi Alan. Wow! I assumed that the pic was in fact Mike's car (with the under grille) but if Ross's pic is Mike's car, then my first pic must have been the original. I wasn't aware it was the same car in the Goodwood car park, despite the lower grille.
    I knew Mike was building a replica 100S and assumed (wrongly it seems) that at the Ellerslie show, that was his and must therefore have been a replica.
    I was talking to John Holmes from TACCOC (shown in that first pic!) recently and mentioned to him that it is so difficult these days to accurately annotate photographs, as you see a car in the street pass you by, you snap a pic, then you can never tell whether it was a Westfield Eleven or a genuine Lotus. John's comment was that the more Lotus badges, the less chance of it being genuine...
    Thanks Alan for that. Now I have to shift the pic from my 'replicas, recreations and specials' category and into Austin Healey.
  19. #119
    Which is why mine is labelled as Tina Lotus (This is Not A )
  20. #120
    New name,same thread
    Thanks to Steve, and ERC, thread name is now more purposeful, in view of my recent content,enjoy..
    and another Healey shot..or two.....
    My 1965 Sprite,Westmere 1974
    Name:  Cars by Roger Dowding #35 1965 A-H Sprite Westmere 1974 CCI09022016 (790x800).jpg
    a Curve on the road to Snowmass in 1982, full of Healeys ..
    Name:  Healey trip 1982 #53 a Curve of Healeys on to Snowmass CCI10032016 (800x551).jpg
    Mark Donaldson AH 100 and a Sprite 1989 Ardmore Reunion
    Name:  Ardmore Reunion 1989 #4 Healeys on the grid CCI10122015 (800x540).jpg
    Not A- Healey but an FL1, Hire Car version of a London Taxi, Mt Albert 1973, powered by the same basic motor of the Healey 100, just the A70 size, 2.2 not the A90 size..2.7 litre
    Name:  Cars by Roger Dowding #13 1950 Austin FL1 Hire Car Mt Albert 5 May 1973 2 CCI04022016_0008 (791x.jpg
    my Sprite at Mangere Town Centre Gymkhana, Ross Hollings was there too in a Mini Cooper.. 1974
    Name:  Cars by Roger Dowding #36 1965 A-H Sprite Gymkhana Mangere Town Centre 1974 CCI09022016_0001 (79.jpg
