Page 64 of 93 FirstFirst ... 1454626364656674 ... LastLast
Results 1,261 to 1,280 of 1851
Thread: New Zealand Historic Muscle Cars Under HRC
  1. #1261
    Pity you didn't let us know as I might have popped down to take some pics now I have dried out from Sunday!
  2. #1262
    THE AUSSIES ARE COMING.
    Over the past three days, 8 Australian Trans-Am cars have been loaded at the Port of Brisbane ahead of the Christmas Day departure of the ship taking them to the New Zealand Festival of Motor Racing at Hampton Downs. We can't wait!!
  3. #1263
    This is the latest HMC poster I recently put together, using Terry Marshall photos, which Dale will have available for punters at the Festival in January. The main portrait image of Red in the Monza is one of my all-time favourites.
  4. #1264
    HMC racer John Sampson has entered the Festival in his beautiful 71 Capri V6, John has been racing this Capri for 17 years and has never modified it beyond what it should be, no modernised components to improve its performance. When HMC first started Johns Capri fitted without any modifications required and he jumped at the chance to race with proper period correct cars, its was compliant rite out of the box and has a MSNZ COD. Lets face it, the V6 Capri certainly has major motorsport history in this country doesn't it and look at these two "Capri Legends together" awesome. He will be one of 3 Capris racing with HMC in 2 weeks time.
  5. #1265
    Keeping it in the family is Scott and Gareth Sampson's 70 Capri V6, featuring all the V6 performance know-how from father John the two boys will be out to see if they can beat dad at the Festival, but all in the spirit of HMC though. Scott and Gareth have joint driving duty's one each per weekend. Come out to Hampton Downs, Festival of Motor Racing, Jan 16 to 24th and watch the battle of the Capris. Once again a fully compliant HMC car with MSNZ COD.
  6. #1266
    Really fully compliant? Are you 100% sure about that? I was under the impression that a Carpi was only ever factory fitted with a 4 speed manual box. Ford (UK) did not introduce a 5speed until 1982 with the release of the Sierra which is post 78 and outside the Mark I Capri production range which is 1969-1974.
    Mike L
  7. #1267
    Jan 2012
    Auckland North Shore
    Quote Originally Posted by nzeder View Post
    I think they got the 5-speed with the 2.8 injected model circa '81.
  8. #1268
    Quote Originally Posted by Paul Wilkinson View Post
    yep that is my understanding too the Mark iii which is like comparing a 66 mustang to a 86 mustang. Sure still a mustang but different chassic, body, specs. However there are some marques of cars that did span a large era with only minor changes mainly under the skin aka Datsun 240z, 260z and US spec 280z all S30 chassic from 69-78 there are 6 different bodies I have seen in these Datsun Z cars mainly around chassis rails, tunnel, diff mounting etc minor improvements in design or safety requirements. Also a Austin/morris/rover mini is basically unchanged from 1959 to 2000 again changes for safety or under skin improvements but basically same suspension, brakes, engine configurations throughout that range.
    That can't be said about the carpi a Mark iii is very different in look and specs to the mark i.
    If you have a set of rules you should stick to them and not make a rule and skip it for x and enforce the rule for y.
    Mike L
  9. #1269
    Yep, its like saying YB Cosworth engines were standard on all MK1 Escorts.
  10. #1270
    agree with above, but the mini has about 140 different models as will, not counting south African models , from 1959 to 2000 mk1 mini is different to mk6 mini
  11. #1271
    ...and crossflow heads were standard on 1950cc Wolseley 1500s and Minis.
    We shouldn't confuse standard with period, or with legitimate run ons - if the rules allow it.
    Once again, we have to be careful that an over reliance on rules doesn't overshadow the 'chocolate fish' and camaraderie. Of all the people involved in classic racing, the Sampsons would be one of the families who epitomise what it is all about. However, if you have tight rules, then you have to enforce them.
  12. #1272
    Southland
    Imagine how fast those Capri's would be with a HD Siamese bore block & stroker crank, they could go out close to 4.2 liters (255 cu in ) in that form, those mods seem to be quite acceptable for HMC.... wouldn't even need a fifth gear!
  13. #1273
    And a very good point. If done in period with proof why not. Or even if it could have been done why not (ie V8 rover into a MG Magnette could have been done so why not today?)
    Having said why not a YB into an Escort? It just needs to be classified correctly 86 vintage engine so if under T&C rules cars needs to be classified as 86 era and rules applied if T&C is your guide/rules.
    Now this is why ERC series works well as the handicaps are used as the performance leveler.
    If you have rules and are trying to enforce them I tip my hat to you but then enforce them and not one set for X and another set for Y. But I see we are not alone in NZ with these issues it is an issue in all forms of motorsport it seems. Always has been and always will be, as it was as it should be
    Mike L
  14. #1274
    Hi HMC & HSC racers, only 8 more sleeps before Hampton Downs starts shaking again. As I have not received any COD's from you I assume you all have one and will be bringing it to the Festival. Assumption can be a risky thing however, the register we are building will eventually have every HMC & HSC COD held in it. As indicated in my Auditors report I will collect yours at the Festival, scan it and courier it back to you - guaranteed. Also ensure it has the RED MSNZ stamp on each page, if not your COD is not valid. Please make yourself known to me so we can put faces to names and discuss where you are at - car and COD wise.
    Dave Graham
    MSNZ COD Auditor
    Licence # 23013
  15. #1275
    Dave- you have already previously made a copy of my COD, do you still need me to bring it out anyway?
  16. #1276
    Hi John, as long as there are no variations to your car from when you submitted your COD then you're cool. I shall take it as read that your COD and car is kosha.
    Cheers Dave
  17. #1277
    Dave- I have changed a tandem master cylinder to twin single cylinders- how much of a spanner in the works is this?
    Tyres are now Hoosiers.
  18. #1278
    John, have PM'd you
  19. #1279
    HMC Invercargill racer Colin Dawson shipped his 68 Camaro up to Tauranga earlier in the week for some minor work, he’s hot keen to be at the Festival and will be his first time at this track. Since purchasing the Ex Allingham Camaro which was already HMC compliant, he has since removed the 427 big block engine and fitted a Roy MacDonald built all iron 377 SB engine making about 630HP, and Jerico 4 speed gear box, still retains its 12 bolt diff but just had a tru trac fitted. See ex speedway/sports sedan racer Colin Dawson pedal this Camaro around Hampton for the first time on January 16th to the 25th.
  20. #1280
    Thats one neat piece of kit that the car travels in.
